6" Clausing/Atlas
Paul in OKC
Oklahoma City, OK, USA.
I don't think the guy had even got around the corner after buying the little lathe I had (7x12 Microlux) before I thought, "I should have thought about that a bit more". Oh well. This little jewel popped up on CL and the guy lives almost just around the corner. Got it for a bit of a trade and some cash. I turn and refurbish roller skate wheels for some folks, and this is already working well for that! Came with a 4 jaw (no 3 jaw) and the change gears plus live and dead centers.
Dalecamino
Local Chapter Leader
Indianapolis, In.
Some guys get all the deals.:biggrin: Awesome. Is that your dial indicator? How does it read for run out? Thanks for showing it Paul.
Carl Fisher
Cape Coral, FL
I used to get my wheels regrooved pretty regularly but it's been years.
Skated on the same set of wicked lips for probably 15 years before I finally quit all together.
Nice lathe by the way :biggrin:
Paul in OKC
Wheel turning. Talk about a challenge, the urethane skate wheels varies in hardness. Takes a special grind on the tool.
And you have to get them all the same diameter? Close? Is that a special cutter/grinder? Sorry I have questions! But this is interesting.
I shoot to get them within a couple of thousandths of each other, not much problem there. It is a special grind on the tool, a piece of HSS with a full radius on the end and quite a bit of positive rake. It also takes a good feed rate so the material doesn't melt back to itself or just tear. This guy gave me 96 wheels to do, this time. Did 40 a while back, and he says he has quite a few more to do later. He collects them, I guess :) I did mine a bit ago. Currently skate on some original fan jet wheels with Labeda 'tires'. Still go regularly. Actually found these skates at a thrift store. Bought them just for the wheels as the boots were small. Wheels are cool!
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
Sigh............
THe last pair of wheels I had trued were wood.
Great little lathe though.............
