Pen stands and displays
NewLondon88
Local Chapter Leader
Claremont NH
added 2 items at the bottom .. just because
Acrylic stands for those doing shows, displaying in craft shops,
consignment shops etc. These are 1/4" clear acrylic.
Singles: 5.75" x 1.5", either oval or rectangle. Corners on the
rectangle are more rounded than shown in pic, but I don't have
another photo to show. Corners are more like on the 2 tier and
3 tier. $2.50
3-Tier stands:
These hold 3 pens, rising front to back. You can get them either with
a rectangle or a trapezoid shaped base. I ship clear acrylic by
default, but have some smoky gray/brown and mirror if anyone
need that. $6.50 ea. (add $1 for mirror)
The 2-tier is almost the same as the 3 tier, but holds 2 pens.
$5.50 ea
The barber pole is a razor stand (for those who do razors and shows)
holds 5 razors. The sides are sandblasted for a frosted look. If someone
wants these for shaving brushes, I can adjust. $20 each. You can add
your name or logo to the base
The tree was an idea for pendants, keychains, earrings and such.. things
that hang . The parts interlock and there's a square ring at the top just
to make sure it holds together. Pretty stable. Doesn't have a base, since
it would make it too expensive, but i can supply a template for the foot \
holes. Or I can get the material and make a base if you want. I just feel
bad that the base would be about as much as the tree! $30
(shown with protective paper still on)
The large stand holds 18 pens. The three shelves hold risers in the center
and slide into the large sides. Slides together easily and comes
apart just as easy if you want to pack it up after a show. $50 for the
large display stand with clear shelves and black sides. You can add
name or logo if you want, price depends on the artwork.
(thanks for the photo, Lenny!)
The shelves are good for displaying a lot of small items at a show. It has
3 shelves 20" wide x 5" deep and they have pins to hold them in place.
You can put a back on it if you want. A dark cloth works to keep the
focus on the items instead of staring through the shelves. $60 ea.
The last one came to me from Jon Piper. He wanted something
a bit bigger than the single pen stand, but wanted the pen tilted
and standing up. So he drew it out and sent it to me to try. Came
out pretty decent, if I do say. The top of the large post is bent to
hold the top of the pen. The bottom post is bent at the base to
hold the nib. Comes with extra bottom posts because some will
place capped pens, some will place sierras or slims.. and the
nibs are different sizes. So .. extra posts with different size holes.
$12 ea. I'll take off $1 if you want to bend your own acrylic
Stands can be custom engraved. Use my screen name at Yahoo
to send artwork
Please don't clean with solvents unless you anneal them first.
They can be cleaned with mild dish detergent or plastic polish,
but if you hit them with a solvent, they'll craze.
To anneal, heat to 180°F for one hour per mm
Shipping is whatever USPS charges.. but I try to stay with at least
the small flat rate box. Otherwise things tend to get broken.
Drop me a PM and I'll get them started!
Adding this item in case someone wants to order them
for Father's day (or any other gift) Whiskey stones are
soapstone cubes that you put in the freezer to chill and
then put them in your scotch, bourbon etc. to chill it without
diluting it. (brings it down to cool, not ice cold) Box has
a self draining tray and is engraved. You can customize the
engraving with your own logo or artwork.
reg. $30 with box, IAP members $22.50
The last one is something I'll be trying. This pic is just a
mockup to see if there's enough interest here for me to
start stocking the hardware. These would be good for shows.
Pop up banners roll up like a window shade (well, roll down!)
and have a metal case to protect the print. Prints are 36"wide,
8' tall. Comes with a shoulder bag and weights under 10 lbs.
Put three together to form a wall behind your table. That's
72 sq feet of advertising space. Setup or takedown is 30 seconds.
Prints can also be changed. Not 100% sure on pricing yet as it
would depend on volume discounts, but probably in the $150 range
including the print and carrying case.
NewLondon88
Claremont NH
had some questions on the Whiskey Stones..
there's 12 stones in the wooden box. Simple
engraving (text) is no charge, as is camera ready
artwork. if I need to do more to it, I'll contact you
beforehand. Camera ready is black and white, not
grayscale or 'desaturated'.
Get a set for Dad. After all, you're probably the
reason he drinks.
