Carbide Cutter Kit for Vega Midi Duplicator
hanau
thomasville, nc, USA.
I was asked to make a Diamond Shaped Carbide Cutter for a Vega Midi Duplicator.
Here is my version of the cutter.
$65 shipped.
You will receive 1 bar and 1 insert with screw.
Bar measures Approx 2.125" long
.440 diameter
.400 flat top to bottom side.
Rolandranch
Tucson, AZ
Is the insert an EWT size carbide insert? Could you possibly make one for the d-48 Vega duplicator? I can give you whatever dimensions you need. Thanks.
hanau
I believe that is the full size Vega and think the hole is 5/8. If it is I have them just have to get the metal for it.
They do not use the EWT diamond insert. It's uses a thicker insert for I what I believe, it takes more abuse than a normal detailer.
I do have extra inserts that works with this
Rolandranch
Tucson, AZ
Yes, it is a 5/8 hole. I'd like to buy one of these from you. Also, please add an additional insert. Will you continue to offer these inserts for sale? PM payment info please. Thanks.
hanau
Carbide holder and bit for the full size Vega Duplicator.
Bar is 5/8" x 3.5" long
