Ice31
It would cost more for the tests but it would be interesting to know what the alloys used in the pot and lid are and how close they conform chemically and heat treat wise to the ones made on this continent. Disproving or confirmation of the oft made remarks about Chinese metals.
I could run a PMI on the pot, but I"m not sure the $200 would be that well spent. I'll call the testing lab that I use and see if they will cut me a deal for the sake of personal endeavor and because I spend a lot of money with them already....I'll let you know
Hate to break bubbles or anything and I am not trying to derail what is going on here but I think we both know the burst pressure of these pots and the outcome of the test. Regardless of the number range or even the material type that it is there are a good hefty number of questions which will not be answered by doing these tests. By all means do the test if you want but ask yourself these: Do they conform to a strict standard in which the material type MUST be adhered to and what is the spec on the material composition? We both know they can and will change according to lot numbers so any testing that you perform does not equate to every pot that is sold conforming to the same spec.
The other issue in this is lets say you do arrive at the burst pressure, which is actually easy to find without doing these test what is to stop people here from seeing that data then performing some grossly unsafe practices because of it? Citing this thread as proof of reliability and be in the unsafe region with a false sense of security.
The simple fact remains it's not about what pressure they will explode at or what material they are composed of. Any student of hyperbarics can very quickly spot the weakness in this approach.
You would be correct, except that i never said that I was going to or did I ever intended to take the vessel to burst pressure. Because that doesn't much prove anything except that I wasted my time. I simply stated that I was going to run the same testing that any ASME stamped vessel would be put through to see if the design and the statement of PSI rating is credible. As for the material you are correct, there is no way of knowing lot for lot what they would be using. But it will give me an indication of the type of material they are choosing to use as a whole. I'll be able to see if this specific pot material conforms to any ASME rated material of if they are using some non-tested "home recipe" for material. More testing is never a bad thing.....how people choose to use the information would be up to them.
