FS - Slimlines blanks
MikeinSC
SC
FS - Slimline blanks
I have solid surface slimline blanks in packs of 10, ready for new homes. There are 10 different colors, enough blanks for 10 pens and the blanks will be drilled through.
Each pack is just $20 shipped.
MikeinSC
SC
Blanks avg 9/16" wide and 2 1/8 "- 2 1/4" long with 7mm hole drilled through the center.
magpens
Canada
Thanks. Would they be 1/2" thick ?
Now, if there are enough in a pack to make 10 slimlines, that would require 20 pieces.
Or am I missing something ? You refer above that these are packs of 10, enough for 5 slimline pens
Please clarify.
mark james
IAP Collection, Curator
Medina, Ohio
I bought a bunch from Mike a while back and was very happy with them!
The modified slims in the middle were from his blanks.
magpens
Canada
Thanks, Mark.
Did you get 20 pieces in pairs ... enough to make 10 pens ?
And do you remember the thickness ?
(Your picture shows 11 pens, several of which seem to be wood)
mark james
Medina, Ohio
Thanks, Mark.
I'll let Mike answer as to what he has now. But, when I bought then, yes, they were of equal size, for 10 slims, 20 in a pack. But I don't want to answer for what he is selling now. And yes, only the MIDDLE pens in the picture , Corian I believe, were from Mike.
MikeinSC
SC
Magpens,
They are 1/2" thick and 20 pieces total, 2 of each color for upper and lower barrels and enough to make 10 pens. Shipping to Canada would be extra though. A pack of these usually weighs just under 1lb. When I send my kitless pens to Canada, which averages 5oz total weight, that's around $13.
