CORKSCREW KIT
wood-of-1kind
Toronto, ON, Canada
I am offering a "build your own corkscrew" kit for sale at $5.00 each USD with a M.O.Q. of five (5) kits per order. Shipping will be via Canada Post for
$7.00 regardless of quantity ordered. If you have a NEJE laser then you can easily engrave your customer's name and really made it a special offering and maximize your sales potential.
The kit is very simple to assemble and you can customize to suit your individual taste. You can use similar wood/acrylic and offer the corkscrew to complement your bottle stoppers and thereby achieve a matched look (see picture# 4). The .pdf attachment gives further insights as to what the kit contains.
PAYPAL is preferred. Thank you for your consideration
  • 0475_001.pdf
dcannon
Toledo, Oh
Cool idea. What size is the plate section, if I wanted to use my own wood/acrylic (or what size blank do you recommend), and are you able to ship to the US?
Thanks,
Dan
wood-of-1kind
Toronto, ON, Canada
Thanks,
Dan
Hi Dan,
yes my primary market has always been the US and have no problems with cross border shipments. I will give specific dimensions of the steel plate when I get home. As for size of blank to use on the corkscrew that is totally up to the end user. If you like a "larger" corkscrew then you can go say 4" wide and 1/4" thick scales. Personally I like a 3" width and I like to round over the edges with a round over router bit. I have also used a chamfer bit to give it a more "modern" look. The possibilities are endless.
Please check back later in the evening and I will post size of the plate.
Thanks.
wood-of-1kind
Toronto, ON, Canada
BUMP ... BUMP These are real nice for personal gifts for the wine lover in all of us. Give these a try and I know that you will have no regrets with the quality of these kits.
Thanks.:)
