3/4" Corian Blanks
Bill Dunn Jr
West Bradford, Pa
I have seven colors of 3/4" Corian available.
This is solid Corian, not glued up pieces.
The price is $2 per blank with a 10 blank minimum plus shipping.
Shipping for a small flat rate box is $7.15.
I do have slabs available if needed, pm me to discuss.
Please order using the numbers on the blanks in the picture below.
It's hard to see but number 3 is a solid light pink.
I will post in this thread when I am out of a color.
I have posted a couple of pictures showing what a few of the colors look like when turned. The single pen is number 6 with an accent stripe.
On the left in the picture showing several pens is number 5 with an accent stripe. The center pen is number 4 with an accent stripe and the one on the right is number 3 with an accent stripe.
Thanks,
Bill
  • pink corian blue accent - black walnut - black corian - figured aspen - pink corian green accent.jpg
eajacobson
Bloomington, Minnesota
What is the typical length of these blanks?
A rough idea of how many fit in a SFRB?
In the several pens photo, I take it that the left-center and right-center pens are not Corian, since you don't describe them in the ad.
Thanks,
Ed
Bill Dunn Jr
West Bradford, Pa
Thanks,
Ed
The blanks are approximately 3/4" square by 5" to 5-1/8" long. I say approximately because they vary by 1/32" or so in thickness from the manufacturer.
The last time I did this I think I fit 22 blanks in a small flat rate box.
You are correct, the pens to either side of center in the one pic are not Corian.
Bill
walshjp17
Weddington, NC
Arrrgh! No green or blue.
walshjp17,
If you are interested, I do have some blue and green in 1/2" Corian but they are not solid colors. I have had luck gluing both of those colors using CA glue and making thicker blanks with no visible seam.
Bill
Thanks, Bill. I have some 1/2". I was hoping to try these colors on a segmented pen but need to have at least 3/4".
