ttpenman
For Sale: Woodtec cast iron Miter Trimmer, like new, hardly used at all. My picture frame project never came about. Make your miters fit perfectly by trimming to a smooth and accurate miter. Packed in the original box. Details:
WOODTEK CAST IRON MITER TRIMMER
QUICKLY CLEANS UP MITER CUTS FOR AN ACCURATE FIT EVERY TIME
Quickly cleans up miter cuts for an accurate fit every time. The Woodtek® miter trimmer cuts like a razor and works with a shearing action: Right or left cuts can be made at any angle from 45° to 90°. Cutters are resharpenable and easy to remove or replace:
Optional replacement cutters come in a matching pair.
Miter cut should first be made with a saw and then trimmed for a precise, glass smooth fit; totally eliminates the need to sand.
Not only reduces the time it takes to make a perfect miter but also increases the quality of workmanship.
Heavy duty cast iron.
If you want to see a photo, check this link:
Woodworker.com: WOODTEK CAST IRON MITER TRIMMER
Price is $170 and I will pay 1/2 shipping, FedEx Ground/Home.
