"quilt patterns" laminated pen blanks.
endacoz
Brookfield, NY
I am looking for laminated pen blanks like ones that come up with you google search woodcraft laminated pen blanks. I'm looking for blanks that resemble quilt patters, or complex patters, not just straight laminated blanks.
I'm looking for 4-6. they need to be at least 3.75 inches long x 3/4.
Thanks!
These will be turned into sewing seam rippers.
Toni
Phenix City, Alabama
I have a bunch of these Quilt Patterns done on 8mm tubes for seam rippers.
They are done in Polymer Clay very easy to turn!
Hope they are what you are looking for :)
stuckinohio
Columbus Ohio
One thing I found out is that the PSI seam ripper/stiletto combo uses a long tube. If you use a tube length that is shorter than 3 inches with that combo (the length for the CSUSA seam ripper necklace kit), and you are using the seam ripper with the stiletto stored in the tube, the stiletto makes contact with the seam ripper and forces it out the tube a short distance.
