Four Jaw Chuck
Kragax
western new york
I'm looking for a used, and hopefully affordable four jaw chuck that will allow me to drill blanks on the lathe. I have a HF lathe with a MT2 headstock.
Something that even bolts to the faceplate would be okay, I have to do this on the cheap as I'm on a fixed income, and not that big of one too boot. So if you know of one please give me a shout. Thanks,.....Craig
BSea
Little Rock, Arkansas
You'll need to tell the spindle size to get a compatible chuck. I'm guessing it's 1" x 8. You should be able to find it in your manual, or on a spec sheet.
JimB
West Henrietta, NY, USA.
A 4 jaw chuck screws onto the head stock so the MT isn't what's important. You need to know the threading of the headstock. Even a cheap one isn't really cheap.
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
As Jim noted, 4-jaw chucks aren't cheap - even used. But you never know, sometimes bargains do turn up.
Just in case you aren't able to score one in your budget, there are a couple of other alternatives. You can buy a new "pen blank chuck" for $71.70 at Amazon.
http://www.amazon.com/PSI-Woodworki...1430236962&sr=1-1&keywords=pen+drilling+chuck
It's a 2-jaw chuck & not nearly as versatile as a 4-jaw chuck, but it's fine for drilling pen blanks.
An even cheaper alternative is to buy a second MT2 Jacobs chuck to hold the pen blank in the head stock. You will need to first mount the blank between centers and turn a short tenon on one end a little under 1/2", but then you can use a Jacobs chuck to hold it while you drill. You can get one from Harbor Freight for $15.00 & sometimes you can find them on sale.
1/2" MT2 Mini-Lathe Drill Chuck
Best wishes
Edgar
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
Taig makes a 4 jaw scroll chuck for around $75.00 and shipping. You will need an mt2 to 3/4 16 adapter. Both are available on line. Ebay if nothing else. it will still run you $100+ to do it this way. Dont know if your budget allows this or not. Used ones are hard to come by.
larryc
Mableton, GA (Near Atlanta)
I've had two of these and the jaws sprung on both of them.
Best wishes
Edgar
Just my 2 cents
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
Amazon.com: PSI Woodworking Products CSCPENCHK Dedicated Pen Drilling Lathe Chuck: Home Improvement
Best wishes
Edgar
Just my 2 cents
Thanks Larry,
That's good to know.
I have no need or interest in one for myself, but I'll definitely keep that in mind anytime someone asks in the future. There's a reason for the old saying of getting what you pay for.
Edgar
Jim Smith
Lakeland, FL
I actually may have a good Nova Midi 4 jaw chuck for you if you are interested. I will check this evening and PM you the particulars with the price.
Jim Smith
thewishman
Reynoldsburg, Ohio, USA.
Best wishes
Edgar
Just my 2 cents
Thanks Larry,
Edgar
I got one used and have used it for more than a year with hundreds of blanks and it works VERY well. I would highly recommend it.:)
