10 x 10 Canopy - Caravan Classic
tdjumr
Waukesha, WI
Selling my caravan classic canopy. Getting out of the show business. Pickup in Waukesha, WI or may be able to deliver to Northern Illinois.
Heavy Duty 10 x 10 canopy. This is not the run of the mill cheap canopy you see at most stores. This has oversized steel legs for greater strength along with a thicker canopy top. The canopy has 7 ft clearance, higher than most. This was bought for arts and craft shows and will last. The canopy has only been used 5-6 times and in excellent condition.
Total cost of the parts bought separately is $581.89 plus the cost of the corner weights.
Asking $400
Caravan Classic 10 x 10 Canopy $399.95
http://www.ecanopy.com/cacl10x10wip.html
Caravan Commercial Roller Bag $81.99
http://www.ecanopy.com/cacorobag115.html?refnum=AUG-131-1884
Poly-Taft 10ft Sidewalls (set of 4) $99.95
http://www.ecanopy.com/capo10si.html?refnum=AUG-131-1884
Custom set of concrete filled PVC corner weights
Specs:
10' x 10'.
Weight: 64 lbs.
Maximum Clearance Height is 7 Feet.
Frame has 4 legs.
Peak Height is 11 Feet.
Height Settings: 5 at 3.5" Apart
Folded Size: 62" x 8.5" x 8.5"
Box Dimensions: 63" x 12" x 10"
Comes with Professional 500D Polyester.
For business or for pleasure, this canopy sets the high standard! Our enhanced steel frame features our exclusive pull pin design for fast, easy operation. Our textured powder coating seals in years of lasting durability. Our industry leading height clearance keeps your enterprise protected and open and inviting. Top it all off with optional custom graphics, including your logo, on bright colored fabric and you'll have an oasis full of action!
