South woods turner, - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Local Chapters > Central Arkansas
  Forgot Password
Reply
Old 04-11-2013, 01:14 PM   #1 (permalink)
Phillip Kelley's Avatar
Photos: 0
Default South woods turner,
Hey ya'll, I have just joined IAP & am from southeast arkansas. Do you
all have regualr meetings and do you welcome new members?
Phillip Kelley is offline   Reply With Quote Top
Old 04-11-2013, 01:43 PM   #2 (permalink)
asyler's Avatar
Photos: 0
Default
welcome ,, i in bryant, i think the next meeting in is may,, i 'm sure bob or scott will jump in with the correct info,,
__________________
Wayne
Central Arkansas IAP Chapter Member
asyler is offline   Reply With Quote Top
Old 04-12-2013, 06:44 AM   #3 (permalink)
SDB777's Avatar
Photos: 1
Default
Everyone's welcome!!
The info about the next meeting can be found: may meeting
It'll be at Joes' place in Greenbier(just north of Conway on Hwy 65).
Scott (hope ya can make it) B
__________________
SDB777 is offline   Reply With Quote Top
Advertisement
Old 04-12-2013, 09:15 AM   #4 (permalink)
BSea's Avatar
Photos: 51
Default
Hey Phillip. We welcome anyone who has an interest in turning, or anything wood related. Our meetings are always fun and relaxed. Usually there are a few demos, and a pen swap that you can participate in, or just watch. We usually have some sort of pot-luck, but that's determined by the host. Just watch this forum for information. I'm sure Joe (aka Dustygoose) will give updates when the day gets closer.
__________________
Bob
BSea is offline   Reply With Quote Top
Old 04-14-2013, 08:38 AM   #5 (permalink)
Photos: 0
Default Poor finish
I need advice on what I am doing wrong with my finish. I begin sanding with 400 grit & progress to 12,000. I also turn the lathe off & sand with the grain between grits. I have slowed the lathe down when I apply the CA glue. I have experimented with paper towels, old rags, and t-shirts and various quantieis of glue. I have tried the activator, but it turned the finish a milky color. I have settled on a paper towel for applicator & no activator! Under the right light scratches appear. On this pen I thought I hadsolved my problem until I took the picture... Well how do you post a photo?
Old 04-14-2013, 10:58 PM   #6 (permalink)
BSea's Avatar
Photos: 51
Default
Are you wet sanding? If so, that may be the cause of your milky finish. What kind of wood are you trying to finish? Oily wood should be cleaned thoroughly with accelerator. there is no water in accelerator, and it will remove any oil from the outer layer of wood so the CA should stick without the cloudy finish. Also use accelerator sparingly, and from about 18" away. And a fine mist is most desirable. Hope this helps.
__________________
Bob
Old 04-15-2013, 07:39 AM   #7 (permalink)
Photos: 0
Default
I use the little plasticbaggies.
Oh welcome to our group.
__________________
Joseph Gaspard
Dustygoose is offline   Reply With Quote Top
Old 04-18-2013, 02:52 PM   #8 (permalink)
Photos: 22
Default
Phillip,
I don't think you're sanding properly, I had the same problem a while back and at some point it just hit me. You need to make sure you take off all of the low spots(they appear as shiny streaks or scratches) on the 1st sanding. Here's my procedure, although it varies depending upon how smooth I get it applying the CA:
Always apply 1 coat of thin to act as a sanding sealer after final turning. I start no less than 500, as a skew should get you close. I then move to 800, then 1200. Not alot of sanding, just a few passes. I always cross sand between grits. I then apply about two coats of thin then two coats of medium. I then sand with either 500,800, or 1200 starting out, then up to 1200. When I sand, I make sure 90% of the shiny streaks or spots are gone. Next, apply 3-4 more coats and repeat the sanding....I finish with two more coats, then start the sanding process again. This time, removing 99% of these marks. I sand up to 1200, then to micromesh. I top it off with Scratchx and 3 coats of Huts polish.
The key for me to remove the finish marks was to make sure during my final sanding that all of the shiny streaks and spots are gone by the time I get to 1200. No sense in going to micromesh if you have these marks. Micromesh will not remove enough material to flatten the surface. This made a huge improvement in my finishes. Another thing, I switched to real micromesh.....PSI, Woodturningz, CSUSA and others have it. I was using Hobby Lobby mesh and it cannot compare to the real stuff.
Just my process, perhaps some of these tips will help you. The key is developing a process that works for you, not one straight off of a website. You really got to understand what you are doing and adjust to get the results you want. The version above is my general procedure, but I adjust every time and change it slightly depending upon the wood, ripples in the finish, humidity, temp, etcc.....
Good luck!
NittanyLion is offline   Reply With Quote Top
Old 04-19-2013, 06:47 AM   #9 (permalink)
Photos: 0
Default
Sounds like a CA finish demo. Scott, I been working on a section. If Bob and Shawn don't show, hope i get it right I'll share what I got and did with you
__________________
Joseph Gaspard
Old 04-19-2013, 09:03 AM   #10 (permalink)
Scruffy's Avatar
Photos: 0
Default Welcome aboard..
A lot of great people here..
and they know everything
Scruffy is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
