workinforwood
I'm sure someone has already performed this idea in the past, but I haven't seen it done. I ripped assorted 3/4 stock into slightly larger than 1/16 thin strips. Then cleaned up saw marks through drum sander. Glued all the strips together. Chopped them 22.5 degrees at 1/2 long, all cuts same direction so you have parrallelograms. flip every second one and reglue. The two outside strips where likely a waste of time. I have my doubts the green sumac will survive stock removal into a pen, but who knows. Should be an interesting looking pen, and quite simple to make. The segment on each end is slightly out of alignment, but the blank is more than long enough for a pen, so I'll chop those two out before drilling. Have a great weekend...keep turning!
