The Zen Pen - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 12-19-2018, 10:45 PM   #1 (permalink)
jttheclockman's Avatar
Photos: 104
Default The Zen Pen
I do not keep up with all the latest pen kits available and really have not bought many new ones lately, so I will ask the masses here. Is there any other kit that is similar to the Zen kit?? In that it is a single long tube. Do not care what the cap it. Looking for one with abit more meat on it than the Zen. Thanks in advance.
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 12-19-2018, 10:55 PM   #2 (permalink)
Photos: 0
Default
I haven’t turned a Zen Pen but from what I’ve seen of it the RAW rollerball at PSI looks to be similar. Personally, I like the RAW kit.
Russ
Sly Dog is offline   Reply With Quote Top
Old 12-19-2018, 11:02 PM   #3 (permalink)
magpens's Avatar
Photos: 76
Default
John,
What do you mean by "meat" ? ... thickness of barrel material after turning to correct diameter ?
If that's what you mean, I don't think you will find a "Zen-alike" with greater thickness.
I have turned quite a few Zens. . The brass tube diameter could be changed to a smaller size if you are prepared to fiddle around with the hardware pieces (nib end and finial end) to match with the smaller brass tube. . This would mean customization of these metal parts.
As designed, the Zen uses a 10.5 mm brass tube (so-called) and I am thinking of a reduction to 3/8" or even 23/64" or even less.
The spring diameter (spring goes at rear end, being a rollerball design) may be a minor consideration but you could possibly go down to even a 7mm brass tube and still accommodate the refill.
I have never done such a customization of the Zen, but I think it would be quite possible.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is online now   Reply With Quote Top
Advertisement
Old 12-19-2018, 11:11 PM   #4 (permalink)
Photos: 104
Default
Quote:
Originally Posted by magpens View Post
John,
Yes looking to cast on it so I need more area. No do not want to fiddle. Thanks.
__________________
John T.
My Photo Album
Old 12-20-2018, 01:14 AM   #5 (permalink)
magpens's Avatar
Photos: 76
Default
John,
I don't know what it is you are planning to cast, but it is something that could take up a lot of "meat" (as defined above), by inference from what you have stated.
I calculated the meat thickness (ie. blank material wall thickness after the blank has been turned to finished size) on the Zen.
The thickness is 0.056", which is not bad when you consider that for the Sierra twist this number is about 0.042", and people do cast things like watch parts in blanks intended for Sierra pen kits.
Personally, for my purposes in using such blanks with "junk" of one kind or another embedded in the casting, I like to see a finished blank thickness of 0.060" or more ... but you don't often get that.
So, the Zen blank thickness of 0.056" is getting close to my target.
I hope I have done the calcs correctly. . Based on data I have, the finished Zen blank is designed to be 0.512" and the Zen brass tube diameter is 0.400". . These numbers result in a finished blank wall thickness of (0.512 - 0.400)/2 = 0.056".
Of course, this number applies to the ends of the blank where it meets the nib and finial hardware pieces. . Note that the finished blank does not need to be turned with precisely uniform diameteralong its length. . There could be a slight bulge in the middle, depending on the aesthetic tastes of the turner. . And if there is a bulge, the available thickness for "junk" would be greater than 0.056".
That's all I intend to say, unless you require any clarification.
__________________
Mal
Old 12-20-2018, 03:19 AM   #6 (permalink)
More4dan's Avatar
Photos: 5
Default The Zen Pen
The Graduate magnetic is a little meatier than the Zen with a turned cap and a long body. The Vertex Magnetic has the same dimensions as the Graduate. Both are 0.516 OD at the ends with a 0:400 tube.
When I get to work later today, I can scan my spreadsheet of pen kit data and see which kits have the max blank thickness along with barrel length. What are you targeting?
Danny
More4dan is offline   Reply With Quote Top
Old 12-20-2018, 03:56 AM   #7 (permalink)
skiprat's Avatar
Photos: 227
Default
Does it need to cost less than $35 ??
__________________
www.skiprat-pens.com
skiprat is offline   Reply With Quote Top
Old 12-20-2018, 09:22 AM   #8 (permalink)
Photos: 104
Default
Quote:
Trouble maker
__________________
John T.
My Photo Album
Old 12-20-2018, 09:24 AM   #9 (permalink)
Photos: 104
Default
Danny
Dan I will look at the graduate. I want to stay with the Zen profile. Long and straight. I know about Sierras and and other kits with more meat such as Majestics. If i know the kits names I can look in the library to see the charts unless they are a new kit and not have been updated. Thanks.
__________________
John T.
My Photo Album
Old 12-20-2018, 11:35 AM   #10 (permalink)
EBorraga's Avatar
Photos: 80
Default
I like the zen. You can get a lot of stuff on the tube. And it's quite a bit under $35.00 :)
__________________
Wicked Chickens lay deviled Egg's
Check out my Facebook page at https://www.facebook.com/EBWoodworx/
EBorraga is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
