beloff
Yes, I am fairly new to turning, but I get the basic premise that when you spin something and hold a tool against it, it should be circular in cross section. My pens aren't. At first, I was concerned with alignment and runout on the lathe (rikon mini). I brought the tailstock to the headstock with points in them and was satisfied with the matching. I used a dial indicator to check the headstock morse taper (0.001") and a faceplate (0.003").
I put a jacobs chuck in and the runout of the mandrel was ~0.010"
with one of the "professional" mandrels with the 1/4" collet chuck it was 0.008". With another collet chuck, I'm back to 0.001" at the headstock.
so, I got some bushings for some atlas-style pens and wall st/gatsby types and started turning. I adjusted the tailstock so that it was snug but not tight, and tightened down the mandrel nut to where is was also snug, but not too tight. result-oval tubes.
I noticed that the bushings fit to the mandrel had some slop and they were noticeably not traveling in a circular orbit when turning. is there some accepted fit for a bushing/mandrel connection? Is there any way to fix the bushings that I have to make round pens? is there a manufacturer who is known for producing bearings with a tight fit to a standard mandrel?
by the way, yes, I am aware of the two mandrel sizes. I have purchased all of my kits from penn state and woodcraft who use the standard ~1/4" mandrel.
