Jim in Oakville
Hi,
I received my latest goodie box today from CSUSA. Included in the box were the Woodworkers Pencils I had decided to try out. I thought that after reading the instructions it sounded simple enough for a kit with no tube.
The instructions state a few details that I followed. The instructions call for a 1x1x5 blank. Reading deeper into the instructions they ask for the blank to be 4 9/16â€. It also states that I am to treat the end into the wood and use either epoxy or thick CA, so I imagined that I would actually manually thread the hardware into the end, unthread it, apply glue and then rethread.
Things were very different.
I drilled the blank I chose, cutting it back to 4 9/16â€. I then turned it using the bushings provided, turning the writing tip flush to the bushing. I then tried to fit the hard ware and discover two things that I was not pleased with.
First, the turned wood was under diameter to the hardware even though I turned it to the bushing. I used a vernier caliper and measured the hardware diameter, it was 0.495â€, the bushings were measured at 0.453, the instructions called them out as 0.466.
Second, the hardware did not engage the wood, it rattled inside the 10 mm hole. I measured the hole, it was 10.1mm.
Oh there was a third, the instructions called for a blank 4 9/16†long, well the hardware is not long enough to extend out of the end of the pencil body at that length, so I cut the length of the turned pencil, by eye….salvaged the tip by measuring it with calipers and just left it drying in the shop with a healthy application of epoxy on the threads…..I sure hope it engages.
So, any tips from people who have walked this mile ahead of me……what did I do wrong, the instruction sheet is . This was not fun![B)][B)][B)]
