ThinkBlot
For those of you who use CA finishes on wooden blanks, what is your method for sanding the blank slightly recessed to the bushing? I turned a pen today (pictures to come later) that I wanted a CA finish on, and had a difficult time getting the diameter of the blank slightly smaller than the bushings while retaining an constant diameter. I tried using the edge of some sandpaper, tried micromesh sheets, tried either folded in half, and tried either wrapped around a piece of square stock... no matter what method I try, I have a difficult time getting all the way into the shoulder at the edge of the blank and the bushing. The blank continually wants to flare out toward the bushing edge here. Today I ended up taking the blanks back off, and sanding the flare down by hand, then remounting to clean it up and apply the CA finish. Surely there is an easier way?! How do you folks do it?
