Hi Dan,
It may be that the PSI mandrel is thinner. Of all the mandrel shafts out there, I think PSI's shaft specs out consistently thinner than all the rest. We're not talking a very big margin here. But if you're using a PSI mandrel and Woodcraft bushings, and you notices a little slop in the bushings, I would jump to the conclusion (correctly or not) that it was because of the thinner PSI mandrel. Conversely, if you are using PSI bushings for a PSI kit on a Berea mandrel, and the bushings are tight or just don't fit, again I would blame this on PSI's mandrel being thin, and the bushings from them being made to match. Just guessing, but I think this might be what you were looking for.
Scott.
