Woodchuck Pen Pro Inserts
tangoman
Australia
Carbide
Burlman,
Yes, those will fit, just pick the size to match. I've used them for a while and they fit and are a lot cheaper !
Regards,
Cam
dtswebb
Modesto, California
Wade hit it on the head. Global Tooling is great to order from. In the eastern portion of the United States, I'll also recommend Oella Saw and Tool as another company that carries the inserts and takes good care of the customer.
plano_harry
Plano, TX 75093
Yes, the only problem is they are SO sharp, the top is like a mirror and reflects light in your eyes! but you can paint them with a marker
endacoz
Brookfield, NY
I am fairly new to the carbide turning. I ordered some from captain Eddie. as many of you know he is currently still under the weather.
does anyone know if the cutters on this global website will fit the square bars that Captain Eddie ships with his cutters?
BSea
Little Rock, Arkansas
If you have some calipers, you should be able to measure your current cutter to see what size it is.
jcm71
Chattanooga, TN
Four radius. I've used them successfully for the past two years. In fact my order arrived yesterday. Will try them out later on this AM.
