Will Woodcraft Euro Bushings Fit PSI Designer Pen - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 12-05-2017, 09:19 PM   #1 (permalink)
Photos: 0
Default Will Woodcraft Euro Bushings Fit PSI Designer Pen
After nearly a 2-year hiatus I'm getting back into pen turning. I am getting my turning supplies out of storage and this week discovered that the top came off the divided box I had my bushings in, they were all higgledy-piggledy at the bottom of the box they were packed in. I'm at least missing one of the bushings to my Euro set.
PSI/Woodturningz now sells a kit they call the Designer instead of the Euro. I need (well really want) the bushings this week. I can go to Woodcraft tomorrow, but will the Woodcraft Euro bushings work with the Designer series kits?
crokett is offline   Reply With Quote Top
Old 12-05-2017, 09:56 PM   #2 (permalink)
Brian G's Avatar
Photos: 4
Default
I measured the set of each that I have.
For PSI's No-tenon designer:
Finial: 0.405"
Upper Center: 0.520"
Lower Center: 0.416"
Nib: 0.356"
For Woodcraft's Euro (Berea) that requires a tenon:
Finial: 0.404"
Upper Center: 0.510"
Lower Center: 0.423"
Nib: 0.359"
My experience with the Woodcraft Euro is that the diameter of the lower center barrel needs to be closer to 0.415-ish to fit the recess of the center band and twist a little easier.
Brian G is offline   Reply With Quote Top
Old 12-05-2017, 11:43 PM   #3 (permalink)
MRDucks2's Avatar
Photos: 0
Default
I have both designer and euro bushings. I have found that if I measure the hardware and bushings, I always end up using a mixed set between the two.
__________________
New Contest for 2019 BASH!
Take a look at the rules for what is considered the fairest, best balanced competition for all members:http://www.penturners.org/forum/f18/...-rules-157766/
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Advertisement
Old 12-06-2017, 08:32 AM   #4 (permalink)
hilltopper46's Avatar
Photos: 62
Default
I used to make this pen sourced from CSUSA, and found that the diameter of the parts varied between plating choices. I used the Penn State deluxe bushing set for all of them, but used my digital calipers to determine the final diameter.
__________________
Tony Rozendaal
East Troy, WI
Turnin' and learnin'!
Recently Created Pens
hilltopper46 is offline   Reply With Quote Top
Old 12-06-2017, 09:34 AM   #5 (permalink)
Photos: 0
Default
I called Woodturningz this morning. I posted this last night because of a) impatience and b) needing to plan my day assuming a trip to woodcraft. The guy I talked to says he has turned several of the Designer sets with the older bushing set, so Im going to go with that. I'll start the turnings tonight and when the kits get here I'll do the final sizing.
Old 12-06-2017, 04:06 PM   #6 (permalink)
MRDucks2's Avatar
Photos: 0
Default
As long as you final size to a measurement you will be fine, regardless of bushings used.
__________________
Be kind &
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
