ToddMR
So my wife had the big lathe motor totally die on her. It's the lathe she likes to use while I use the Jet 1014. Before that I forget what else happened to her too. Then she was using the bandsaw and the blade popped off but didn't break. Then she decided to use my Jet Lathe yesterday and was trying to remove my mandrel saver from the tail stock. Well the metal piece the mandrel rod slides into popped out and the little rubber gasket broke. I have no idea on the size needed to replace it. Her's uses MT#1 so can't take hers and use it lol. She felt bad but I tried helping and that is when the thing popped out.
Since I am back to using my live center should I invest in the 60 degree live center? I am sure most will say yes. I assume it is bigger on the point than the supplied one that came with my Jet. They are only $19.99 at WC so I thought I would get input from here. Thanks again everyone!
I have had good results with my mandrel saver personally.
