This may be a first as far as a question. I like making my Designer pens with more "meat" on them. I also like the rubber comfort grip "grip". I know that I can slowly reduce the lower barrel to meet the top of the rubber grip, but I rather have a fatter grip (toward the top).
So I want a rubber/silicone grip compatible with a 7mm tube, BUT have with larger diameter top (of the rubber grip) so that I can make my lower barrel wider. Does this make sense or have you had to take 6 Excedrin Migraine after reading this ?
Thanks for reading and I owe you some aspirin!
