redfishsc
I have a Delta Midi that is about 2-3 years old. I bought it about a year and a half ago and it was barely used. So far this is what I have experienced.
1) The spindle shaft was slightly warped. Replaced it for ~$25.
2) Niether the old nor the new spindle shaft would accept a drill chuck--- the MT2 on the two drill chucks I have would bottom out on the inside of the spindle taper. I had to use a 1/2" drill bit mounted in the tailstock (where they fit just fine) and hollow out the spindle shaft some more just so the drill chucks would fit the spindle taper.
3) The threads on BOTH of the spindle shafts were too deep. I could not, for the longest time, get anything that threads onto it work right-- they turned out of round. Once I put a thick washer on it (behind the chuck) to allow the chucks to bottom out, they turn true as blue.
4) The tailstock has too much slop in it-- side-to-side motion. Even the Harbor Freight lathes don't have as much as mine does!
5) The quill on the tailstock was just a tad too fat for the cast iron hole that it fits in. I have always fought this, and drilling was difficult b/c the wheel was hard to turn. I assumed it was simply b/c of sawdust getting in the screw threads. I would disassemble, clean, and lube---- -no effect. So I totally removed the quill, mounted it in my 4-jaw Barracuda chuch, and used some 60 grit sanding belt to skinny it up a tad (followed by a tripoli buffing). When I remounted the quill, it extends/retracts smmmmooooootttthhhh and slick. I can give the handwheel a good strong spin and it will, just by momentum, totally retract or extend. Made drilling SO UNBELEIVABLY EASIER.
6) Changing the belt to, or from, the lowest setting is a pain b/c the belt gets pinched in the latch that holds the cover shut. This latch also comes unscrewed a LOT and I had to CA glue them tight.
In other words,
GET THE JET OR THE RIKON.
In other words,
