Why 7mm?
tharp
AK, USA.
Does anyone else feel the same as I do? Why 7mm?
I mean, why can't I just go down to the hardware store and buy a drill bit if I lose or break mine?
I didn't question this until my wife asked what I was ordering on line. I said "a drill bit". She said " don't you have a ton already?.
I said yes, but this one is a "special" one. When she asked what was so special about it, I commented that it was the size of it. She said "Holy Cow, it must be huge".. uh, no dear, it's only 7mm. Then back to the original question "Don't you already have a ton"?
I know... rant, rant, rant. but WHY 7MM?
I mean, I've heard others talk about size "J", but the hardware here just looks at me funny.
WHY 7MM? I want to use my normal set of drill bits. UGGGGGGHH. I want a NORMAL pen kit.
Sorry for the rant but I only had one bit and I can't find it.. WAHHHHHHHHH.
Tom:(
alparent
Gatineau, Quebec, Canada.
I use 9/32. I got a bit set of a gabazilion bits for 50$ Got all numbers, all letter and bits up to 1/2". I can do all the pens kits (almost) with them. Only need to get bits for kits bigger then 1/2", and these are hard to lose and hard to break.
redfishsc
North Charleston , SC
Actually, if I had to bet on it (which us baptists don't do) I would have to say that 7mm is NOT the number they shot for. I would say it is a by-product of using a 1/4" mandrel.
The tube for a 7mm pen fits just right onto a 1/4" mandrel, a cheap steel rod threaded in various ways for various configurations. Then add the thickness of the brass tube walls, and you get a 7mm drill bit (or the J or 9/32).
Now, when it comes to the fact that nearly every pen needs a different size drill bit than every other pen, you got some fightin' grounds for sure.
And aside from that is the way every company pushes friction polish as "the stuff" when in reality it is a waste of money, shellac, wax, time, and friction.
alparent
I know! When I first started I got a bunch of finishing stuff (that I used only once because the results where.......you know!)Got them just because the catalogue was pushing it as THE "easy, fast, even you can do it" pen finish.
Now they are resting in the bottom of a box never to be used again (waste of $$$)
Maybe this would make a good poll?
mikemac
Ottawa, Ontario, Canada.
HEY.. don't blame us.. I'm unable to find a 12.5 MM for the Gent Jrs, (I know, its close to 1/2, but not close enough).
I'm gonnna have to order from the States
gerryr
Billings, MT, USA.
The metric system for measurement is the only truly consistent and easy to understand system there is, everything is either a multiple of or divisible by 10. What could be easier? The problem is that we inherited part of the English system, and just to prove our arrogance we stick with it while most of the world is metric. At least we didn't get stuck with stones for weight.
And, BTW, 1/2" works just fine for Junior caps. I've made plenty of them using a 1/2" bit.
wood-of-1kind
Toronto, ON, Canada
Originally posted by mikemac
<br />HEY.. don't blame us.. I'm unable to find a 12.5 MM for the Gent Jrs, (I know, its close to 1/2, but not close enough).
Not so fast Mike. There is ONE (1) Canadian drill manufacturer left and I'm ordering METRIC drill bits direct. I plan to offer these (select sizes to start) very shortly. And yes, 12.5 mm is one size along with 10.5 mm to do the Jr's.
-Peter-[:)]
kirkfranks
Salisbury, MD, USA.
Just remember that where they make these pen kits they MOST LIKELY CAN go to the local hardware store an pick up a 7mm drill bit any day of the week.
They would probably not be able to find the 9/32.
It's all a matter of perspective.
maxwell_smart007
Lead Moderator
Staff member
middle of nowhere in the great, white North
I like the fact that ONE thing, finally, is done the way the majority of the world does it...metric's the language of the world - only we NAmericaners speak in imperial...
(which is odd - there's no Emperor, after all!)
Apparently, I need coffee - post dinner weirdness!
Grizzlyss
Innisfail, Alberta, Canada.
Like Mikemac said, don't blame us. Canadians were dead set against metric but trudeau had other ideas, and he rammed it up our %$#. But what Gerryr said is true, I must admit. But when it comes to trying to visualize the size of something I still think in Imperial, I still can't think in cm and mm, or even metres. Must be that age thing, I didn't get forced into it until 15 or 16 if I remember correctly, but unfortunately, these days I rarely do. LOL.
Sheldon
tharp
AK, USA.
Okay, I TRIED a 9/32, it slipped right out and the glue never adhered. I'm not sure, but I THOUGHT I heard laughing. As far as "lettered like J", The local hardware store thought I was nuts when I went down there. And it's an ACE store. Go figure.
Maybe just 3 more days before my metric bit comes. I think MM stands for "Money Moochers"
ö¿ö
Tom
workinforwood
Eaton Rapids, Michigan, USA.
Could take more than 3 days, it may never show. I have a $400 CSUSA order for 2 day delivery UPS, well it's been 3 days. @#%$@ UPS driver can't find my house! I have sold all my inventory and only have a couple tubes to work on and no kits, but I do have drill bits [:D] I can only guess the regular driver is on vacation because my house is not hard to find...Just look for the guy standing out front with a megaphone saying ...well you can fill that part in [;)]
maxwell_smart007
Lead Moderator
Staff member
Originally posted by Grizzlyss
<br />Like Mikemac said, don't blame us. Canadians were dead set against metric but trudeau had other ideas, and he rammed it up our %$#. But what Gerryr said is true, I must admit. But when it comes to trying to visualize the size of something I still think in Imperial, I still can't think in cm and mm, or even metres. Must be that age thing, I didn't get forced into it until 15 or 16 if I remember correctly, but unfortunately, these days I rarely do. LOL.
Sheldon
I guess that's the difference - I grew up with Metric, so it's a lot easier to think in Metric than imperial - base ten makes more sense to me than base...? What's the base of imperial?
As for having it rammed down 'our' throats, I think most of what Trudeau did was against the political currents of some, but he tended to get people on his side in the end...
As far as metric goes, I wish more things were Metric up here - the hybrid Metric sometimes and Imperial other times is just too inefficient...and it's weird thinking in Kilometres and litres, and then having people talk about miles per gallon...one or the other! :)
tharp
AK, USA.
Yes, but Canadians decided to get rid of their dollar bill and implemented the Loonies. We just send our loonies to Washington :-(
.... Before anyone flames me, I didn't say which ones. :)
Just kidding guys.
I like traveling to Canada. With the exchange rate, I'm only 35 years old.
BTW, Victoria is GORGEOUS!
Okay, now that we sorted that out, Does ANYONE make pen kits in the US?
Tom
jrc
Bristol, Vermont, USA.
I drill alot of highly figured woods that the bit wants to drift and sometimes the grain wants to close back in and the tube is very tight in the blank. I've been using a 9/32 bullet tip bit from Woodturningz for the last 2 years and they work great.
gerryr
Billings, MT, USA.
Originally posted by tharp
<br />Okay, I TRIED a 9/32, it slipped right out and the glue never adhered. I'm not sure, but I THOUGHT I heard laughing. As far as "lettered like J", The local hardware store thought I was nuts when I went down there. And it's an ACE store. Go figure.
If you used thin CA, it may well not work. I've used "J", 7mm, 9/32, and even used an "I" bit a couple of times. They all work, but I always put a LOT of glue on the tube before I slide it in.
As far as being able to find a letter bit at someplace like Ace Hardware, forget it. Same thing with Lowe's or HD. If you live in a decent sized town, look in the yellow pages under tools and find an industrial supplier. They will have letter and number sized bits.
cdcarter
Birmingham, AL, USA.
I just keep my Harbor Freight super bit set and digital caliper handy and choose the bit out of the big red box that is closest to the measurement of the tube. That's usually tighter than the holes I drill with the bits from the houses.
redfishsc
Originally posted by cdcarter
<br />I just keep my Harbor Freight super bit set and digital caliper handy and choose the bit out of the big red box that is closest to the measurement of the tube. That's usually tighter than the holes I drill with the bits from the houses.
For $40, there is your "almost always the perfect size" answer. I do the exact same thing.
tharp
AK, USA.
What are the long-term effects? Has anyone had problems with the tube walking away over time? I mean, if you can use a 9/32 for instance, why do so many people promote the 7mm? I'm still baffled.
So again, does anyone in the US make pen kits?
Tom
W3DRM
Minden, NV, USA.
As a very new pen turner, I have read that if you use the 9/32 drill for 7mm tubes you have to use a glue that expands and fills the voids around the tube as it cures. Gorilla glue is such a glue while I don't think CA glue expands much during their curing process. The downside of using Gorilla type glue is that you have to wait overnight or 24 hours to begin your turning.
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
Whenever I make a kit that calls for a 7mm tube, I drill 9/32 and use either Gorilla Glue or Thick CA. And NO, there are no U.S. manufacturers of pen kits at this time.
R2
Brisbane, Queensland, Australia.
Open Minds anyone? I'm old enough to have learnt the British Imperial system at school and then had to teach the metric system. We in Oz have also been copping American cars and TV for so long it's not funny, so we had to accustomize ourselves to US pints and gallons. We also cope with both spelling systems, not to mention some quirky American grammar
I've been surprised when I've been in the States at the things I couln't buy considering the size of the market and the obvious economic clout that the Us has throughout the Americas.
Without wishing to be offensive, I've never really been able to understand why there is such a closed mind in America to so many "foreign" goods and ideas.
Perhaps there is an opening here for a US based IAP member to look at importing 7mm drill bits as specialist line.[:D][:D]
madison, wi, USA.
The combination of a 9/32" bullet bit and polyurethane glue works well.
No rush to glue tube.
Need patience to wait overnight to turn.
Larry
http://webpages.charter.net/lgottlieb2/
