White Filler Inlay?
randyrls
Harrisburg, PA 17112
Does anyone use a white filler on pens? What do you use?
I see that Inlace has a white color. I want a "snow" white to use as an inlay...
Thanks for any suggestions....
snyiper
St Inigoes, MD
Randy I use either Holly that is pure white or Derilin from a cutting board is pure snow white and cuts like butter. How much do you need? Corian also works very well. Inlay may be better to use clay in white.
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
I've used PR either with white Mixol or white powder pigment (titanium dioxide). The mixol takes a little longer to cure and may need a little heat to help it along, but is a very nice white. Inlace would be similar and would work well, but is more expensive.
