Where can I find an El Grande front section only?
Carl Fisher
Cape Coral, FL
Had a CA incident that killed the entire plastic and gold section of an el grande. Does anyone know where I might be able to get just the front section? The black plastic and a gold tip for a roller ball.
Thanks!
JD Combs Sr
Owingsville, KY
You might want to get someone else to confirm this but I believe the Churchill/Windsor has the same front section. Assuming that is so you can find it here. Note too that this is a full brass section, not plastic.
its_virgil
Wichita Falls, TX, USA.
If the one from the golden nib will not work I may have one in my parts box. I will look and see. email Anthony and ask him if his rollerball section will work for the el grande. I may have a churchill I could check. I'll check on that also. Look for a report later.
Do a good turn daily!
Don
Carl Fisher
Cape Coral, FL
Shawn, those would be good if it was a fountain that I killed. I'll keep those in mind for conversion possibilities.
JD, nice upgrade option. I'll have to keep that bookmarked for later as well.
Constant, pm on the way shortly.
Carl Fisher
Cape Coral, FL
Thank you Don Ward!
Also thank you to those who were willing to help as well. I learned a bit of a lesson about CA gassing out inside of a pen when you use a drop or two to seal a loose fitting part. Switched over to thread lock from now on.
its_virgil
You're welcome.
Yea, CA is not the best for this. Locktite red or blue is a better choice and cleans off very well. Even two part epoxy is a better choice.
Don
Thank you Don Ward!
