Where can I find 8th in aluminum sheet?
AnachitlPut Member Joined Nov 7, 2010 Messages 308 Location San Antonio Feb 2, 2012 #1 Where can I find 8th in aluminum sheet?
J Justturnin Member Joined Aug 19, 2011 Messages 2,235 Location Houston, Tx Feb 2, 2012 #2 Check your local Big Box in the roofing department.
The Penguin Member Joined Dec 21, 2009 Messages 2,134 Location Houston, TX Feb 2, 2012 #3 1/8" is awful thick to find in the roofing department. at most any Home Depot and Lowes - they sell miscellaneous metals like that in a small bin on the "hardware" aisle
Andrew_K99 Member Joined Feb 17, 2011 Messages 1,571 Location Waterdown, ON, Canada Feb 2, 2012 #4 I'm not sure the big box stores will have 1/8" sheets, however they're likely to have 1/8"x1"x3' flat stock which may work. AK
wiset1 Member Joined Aug 25, 2010 Messages 2,222 Location Florida Feb 2, 2012 #5 Home Depot, Lowes, online like Amazon!
W whegge Member Joined Oct 5, 2010 Messages 59 Location Roscoe, IL Feb 2, 2012 #6 See if you have a Speedy Metals company around you. If not you can order it online with them. I picked up 2 12x12" sheets for right around $10. Also, I have 1/8" aluminum, not much though. How much you need?
P paps Member Joined Dec 7, 2010 Messages 143 Location Bryan, TX Feb 2, 2012 #7 I've had luck finding aluminum plate at the local metal recycling center...they charge by the pound. Paid 0.95/pound for some half inch aluminum last week.
lorbay Member Joined Jul 2, 2009 Messages 3,378 Location BC. Canada Feb 2, 2012 #8 Luke Putman said: Where can I find 8th in aluminum sheet? Click to expand... Depending on size I can get you what you want if you pay the shippin. PM me if interested. Lin.
ren-lathe Member Joined Feb 6, 2011 Messages 343 Location St. Clair Shores, Michigan Feb 2, 2012 #9 Online metals carries all most any metal you want as well as plastics. And they sell in small amounts as well.
G GoatRider Member Joined Dec 10, 2011 Messages 417 Location Maple Grove, Minnesota Feb 2, 2012 #10 Hobby shops should have it, the kind that sell model trains and planes.
