What size is letter "O" drill bit?
Dario
Austin, TX, USA.
I am just wondering since I am about to order some Flat Top/American Ballpoint and I might have that size already.
What size metric or english can I use instead?
Why waste money when you can order one more kit instead right? :D[}:)]
Thanks!!!
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
The "O" bit is a PIA. I find that I have to ream the hole a bit for any of the tubes to fit. BTW, 21/64" leaves a lot of play...too much for my tastes.
Rudy Vey
South Plainfield, NJ, USA.
I use a 8.2 mm bit for all work calling for an "O" bit, before I got these I used a "P" bit. And it works good for me since I also use Polyurethane glue, i.e Gorilla.
Rudy Vey
Originally posted by Geo in Winnipeg
<br />I find the 'O' (.316") bit is too snug as well. I was considering either a 'P' (.323") or a 21/64 (.3281"), 8.2mm = .328". Would the 21/64 be too big if using epoxy?
I think the 21/64 is too big, the 8.2 mm is much better suited, it is pretty much the same as a "P" bit.
8.0264mm =0.316" ="O"
8.2042mm =0.323" ="P"
8.3344mm = 0.328125" =21/64"
Oakville, ON, Canada.
Thanks Rudy, since it works for you I think I'll try an 8.2mm bit. What kind do you use, brad point or split point? BTW I use epoxy as well as Titebond poly glue so a perfect fit isn't necessary.
alamocdc
San Antonio, Texas, USA.
Did a little research, guys. 8.1mm = 0.31914 This place has them for $1.67 - $3.86. Bigger than the O, but not as much slop as the others. Since I use epoxy exclusively, I''ll probably give this bit a try. http://www.msdiscount.com/store/columnar.aspx?cat_id=1201&session_id=558677245
