What should I turn?
Well, I won a beautiful Damascus steel M3 blank from Mike in the Creative Mug Shots. What kit will this look best with? It's 3/4", so I don't know it COULD fit anything besides a 7mm. Any suggestions? Also, any tips for turning and finishing?
Thanks,
Ryan
cwolfs69
portsmouth, va
i would think with 4/3" you could make almost any kit. most of the blanks i use and cast start at 3/4". i do not know many, if any, kits that are finished over .700" round.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Thanks,
Ryan
As others have said, yes IT CAN fit many pen bodies. BUT YOU have to drill it---so if you think you can only make a 7mm---you MAY be RIGHT!!
Most of the popular "two piece" pens use a 10.5 and a 12.5mm hole. 12.5mm=.4921". 3/4"=.75", a difference of .25 (for the sake of easy numbers) which allows you 1/8" all the way around. But, if you and your equipment are not able to stay "centered" on the blank---you could ruin it.
So, do what YOU are comfortable doing. If you have the tools to drill on your lathe---you should easily get this to work. On a drill press----:confused::confused::confused:
ed4copies
Racine, WI, USA.
I was looking at Penn State. Most require a 7/8".
Don't believe everything you read. 7/8" blanks cost more, so a vendor may tell you it is "easier" to get a pen out of a 7/8", therefore THEY recommend it. The caliper and the sizes dictate what is possible---some vendors dictate what is profitable.:eek::eek:
