What is a negative scraper? - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 12-03-2017, 08:59 AM   #11 (permalink)
Photos: 4
Default What is a negative scraper?
Quote:
Originally Posted by wouldentu2? View Post
I would imagine he presents the skew with the heel and toe parallel to the mandrel and use the sharpened edge to remove any uneven ridges from the blank. Thats how I use it right before any sanding. Works great on wood don't do much acrylic.
That is correct with the handle slightly raised and the edge shaving sharp. Not a true negative rake but as Charlie called it like a negative rake. I apologize if my terminology is not correct or I have declared it to be something it is not. . For us it produces an amazingly smooth finish. We do not do hardly any acrylic.
All of our turning is “country grown, trail and error learned ( with a heavy emphasis on the latter. Almost 50 years ago my grand dad spent about thirty minutes showing me what to do at his lathe the rest has been hunt and pick until it works )
Talltim is offline   Reply With Quote Top
Old 12-03-2017, 09:12 AM   #12 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Quote:
Originally Posted by ghansen4 View Post
Tim, would you mind describing how you do this? I'm still not following how a skew can be used like a negative scraper.
A skew is usually used with the handle down and blade upward and cutting in at an angle. When used as a "scraper", it is laying flat on the tool rest, handle presented level to the blank. Since the skew is beveled on both sides, and presenting the blade flat and level to the blank, the blade end is at a negative angle.
Notice that Randy posted a picture and how the end of the blade is ground slightly downward - the end of the skew, when presented this way, the blade edge is also slightly downward. This is a "negative" angle when presented level to the blank.
BTW, this is not what is commonly referred to as the purpose of a skew. While using the skew as scrapper is OK, it is not what wood turners refer to as the intended use of a skew. Skews were originally intended to "cut" . . . not "scrape". But when used flat as a scraper, the bevel of the end comes in contact at a negative angle, ergo "negative scraper."
__________________
Hank Lee
Good is the enemy of Best
leehljp is offline   Reply With Quote Top
Old 12-03-2017, 10:24 AM   #13 (permalink)
Photos: 4
Quote:
We do occasionally use the skew the way it was intended as well.
I used to be into woodcarving. I went to South America and there were guys there sitting on logs in the mesquito infested jungle using tools made from who knows what. They put out work that I couldn’t dream of doing with my Henry Taylors.
I was impressed and thought well what ever works and gets the job done.
Now I do admire people that are blessed to do it the right way. I am just seldom one of them.
Advertisement
Old 12-03-2017, 12:19 PM   #14 (permalink)
Photos: 0
Default
The term has been in the metal lathe world for ages. These are tool bits for a metal lathe as explained in the Machinist's Blog.
dogcatcher is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
