What kits work for Pencil Conversion?
chartle
Pgh, PA
Now that I know that there is a Schmidt Pencil Mechanism converter for Parker Refills my selection of Pencil kits has grown.
Are there any kits that are better or some that just won't work? I've seen the Library article and am assuming that any "twist" pen should work.
Mr Vic
Falcon, CO
Cliff, Take a look at the Perfect Fit with the Schmidt pencil insert. Both the 0.5mm and 0.7mm work fine. I've been trying to modify both kit and insert to work with the 0.9mm. So far I've destroyed them with the old, just 1 more trim.
magpens
Canada
My favorite pen kit for pencil conversion is the Dayacom Long Clicker, sometimes called the Longwood Clicker. I believe that Timberbits calls it an Executive Clicker.
You may need to very slightly reduce the size of the circular ridge at the top end of the Schmidt 2006 pencil cartridge, or, alternatively, ream the hole at the nib end of the pen where you insert the pencil cartridge. I find it easier to do the former using medium sandpaper.
chartle
Pgh, PA
Ok here are the kits I'm leaning to. Note this is a High School Graduation gift and I already have the bushings.
Continental Fountain Pen Kit Gold
and
Continental Ballpoint Pen Kit Gold at Woodcraft.com
magpens
Canada
That ballpoint kit is the same as the Berea Atrax, I believe.
The Schmidt 2006 pencil mechanism works fine in the Berea El Grande. Not sure about Atrax.
Might be a good idea to ask Berea.
