jd99
Did several pens today, and I have one that I made from some blanks that I bought about a year or more ago, and I didn't write down what the blanks were any one know what this wood is?
Also came to the conclusion that I need to make some delrin bushings for finishing, I had a crosscut cedar, and a buckeye burl pen chip on the edge when trying to get the bushings off the tube's.
Also had another pen that had dull spots in th CA tried everything that was suggested in the other thread, the top tube took the CA fine and polished up fine the lower tube wouldn't. It was one of the Jack Dainels barrel blanks that I have; must have been something in the wood. Maybe Wiskey
Sanded it back down and used friction polish.
Also how do you guys turn the 7mm pens between centers, do you make up special bushings? All the other bushings I get for the larger pens, I chuck them up in my metal lathe and cut cut them so I can turn between centers, can't do that with the 7mm bushings cause there is nothing that goes inside the tube.
Live and learn.
Danny
Live and learn.
Danny
