Dvoigt
I been having alot wasted time fixing my CA finish because it has been sticking to my bushings and cracking or peeling when i separate the bushings from the pen. I try to clean all the CA off the bushing before I take it apart but that doesn't always prevent it. So now I'm going to try the change to the manderless method.
I know I need to get the 60 degree tail stock, but what do I use for the head stock? I'm eying the Barracuda2 T/N at PSI... and then would also order 60degree tail stock from them too. It appears that the Barracuda has a head stock drive attachment. Would that work for turning between center, or is there something else at PSI for the head stock that you would recommend that i get in stead (or in addition)
Thanks,
D
Thanks,
D
