what glue do you use when segmenting
PenMan1
Eatonton, Georgia
I try to use medium (gap filling) CA when possible.
When I use metal segments, such as copper, brass or aluminum, I have found that Loctite 5 minute epoxy has a far smaller failure rate in my shop.
HOWEVER, using epoxy on segmented blanks (particularly herringbone designs) is messier than trying to eat a soup sandwich.
HSTurning
New Hampshire
expanding polyurethane glue
unless you clamp the pieces you have a chance of spreading the pieces apart.
CA and accelerator is an instant set
RyanNJ
Burlington, New Jersey
i just made my blank and turned it i can see the tube where i glued i will have to try again..
on a side note i can not pull the top of the pen off to get at the ink refill
Rfturner
Santa Maria, CA
I always use loctite 5 minute Epoxy I have only had one or two blanks come apart out of countless blanks I have made. The only thing that I use CA for is finish
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
I use CA for everything. I use the thin ( quicker) one for most joints and sometimes the thicker ( slower ) one where I need a little time.
I degrease ( with isopropanol alcohol) all metal just before gluing.
