dlindquist
What do Jet 1220 bearings sound like when they are going bad?
Originally posted by ed4copies
How does one DESCRIBE a NOISE?????
In German, dogs don't say "woof". Even MAKING animal sounds in China, we never figured out WHAT we were EATING!!!
How do we DESCRIBE a NOISE?????
Originally posted by dlindquist
Thanks, all. Especially Randy. I looked in the library before I posted, didn't see anything. I'll go back and have a look a that article, in case I need to changed them. olivier is right, I think, all new noises are bad. Its also starting to make a new noise when it starts up, a quick, quiet thump sound, kind of. ( Sounds are hard to describe.) That one can't be good either. Well, thanks again. Wish me luck. I need to get it solved, since there are not enough pens in the world. Dave
Originally posted by TAld
Another way to check is to use a mechanics stethoscope and probe each bearing until you find the bad one. They are available from Harbor Freight for about $7.00. Also make sure bearings are rated for the RPM's you need.
.....I looked in the library before I posted.....
Would a stethoscope be sensitive enough the allow one to figure out which of the two bearings was making the noise?
