Add to this, with your gouge sraight on presentation, bevel rubbuing, you're scraping.
Same presentation, bevel rubbing, roll the gouge slightly to either side and lift to engage the cutting edge, slide it along and when you hit the "sweet spot" thin ribbons pour off the gouge.
Helps to "break" the edges 1st with sandpaper. Then start in the center of the blank (more supported).
