I see talks about BLO catching fire but, what is it? Also, what does PITH stands for? Cheers PD
PedroDelgado Member Joined May 3, 2011 Messages 92 Location Lawrenceville, GA 30043 Oct 5, 2011 #1 I see talks about BLO catching fire but, what is it? Also, what does PITH stands for? Cheers PD
Drstrangefart Member Joined Sep 15, 2010 Messages 4,258 Location Woodstock, Ga. U.S.A. Oct 5, 2011 #2 Boiled Linseed Oil, and Pen In The Hat, respectively.
alphageek Former Moderator Joined Jul 19, 2007 Messages 5,120 Location Green Bay, WI, USA. Oct 5, 2011 #3 Check out this from the library! http://content.penturners.org/library/general_reference/Acronyms.pdf
StephenM Member Joined Apr 16, 2011 Messages 535 Location Webster Groves, MO Oct 5, 2011 #4 Boiled Linseed Oil. It can really make some grains pop in a big way but the wet rags can catch fire by spontaneous combustion. Just be sure to lay them out flat to dry or put them in a fireproof receptacle.
PedroDelgado Member Joined May 3, 2011 Messages 92 Location Lawrenceville, GA 30043 Oct 5, 2011 #5 Wow! Pretty wild. Thanks!!!
