webmonk
Hi guys,
I'm starting a thread for the discussion of the technical aspects of the inventory system to better separate out the conversations. Here's the latest suggestion:
Definitely. I want to do that plus store the minimum sizes needed in a pen kit so that later we can show a list of blanks in stock that would work with a certain kit. For instance, I like turning the Panache pens, but they require a blank that's nearly 1" square. It would be nice to get a quick list of which blanks would work for me.
I'm going to work on this once the basics are satisfactory.
Jon
How about adding size column on the blanks? knowing it will help a lot what kit you can use.
3 tier group should be sufficient like slimline (less than 3/4"), regular (3/4" - 13/16"), Jumbo (7/8" and bigger)
Dario
San Antonio, TX USA
"Innovate or Stagnate"
www.AOTurnings.com
Fine Handcrafted Writing Instruments
Jon
