Skeels
So the more I've been turning, the more I try and get a piece of wood or casting that's pretty close to the final product. I normally cut my puente wood and cast alumilite myself instead of purchasing blanks. Not only can it get costly but I'm reality, when u buy a 3/4 square 5-6" long for a slimline... Ur cuttin off near 2" and wasting a lot of material turning it down to about 3/8"... Se with the alumilite casts. I started doing 3/4 square by 5.5" for my cigar pens. I recently started getting closer and closer to the diameter of the pens I've been turning. For instance rather than casting square, I cast in PVC pipe. Rather than cuttin 3/4 square by whatever length, I cut per pen and as close to the wd size as possible.... Why waste it right? Just wondering what some of you guys do to get every bit of material out of... Well your material.
