avbill
There has been several trends about aluminum pen blanks. I am assuming the maker drilled the blank for the brass tube. Would it not be lighter in weight if you drilled for the OD of the nib and clip verses drilling for the tube. Would it not be better if you drilled for the OD of the nib and OD for the clip in wood because the wall of the wood or acrylic is thicker.
Or is the expansion rate of wood throw this theory out the window. I'm thinking through th reason or the brass tubes and where I can eliminate them. resulting in a lighter pen.
Bill Daniels
Bill Daniels
