Upgrading buffing wheel... 6 or 8"? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 02-15-2019, 12:31 AM   #1 (permalink)
Quality Pen's Avatar
Photos: 4
Question Upgrading buffing wheel... 6 or 8"?
So, I have 2 questions....
Right now I use 2 6" wheels on a 3400RPM grinder. I heard that slower is better, and I also want to use more than 2 wheels in the hopes of saving time.
1) Is there any benefit when it comes to 6 vs 8" wheels?
I know people say speed matters, and an 8" will give a faster (inferior) surface speed, but is it enough to matter? It looks like a 8" wheel gives about a 1/3 increase in surface speed.
My other question is... what are some good options? The suprising thing I read on one of the few slow speed buffers I can even find - https://www.rikontools.com/product/81-608 - is that its recommended run time is 30 minutes. I almost gasped when I read that, considering I didn't think that was even a thing... but I would need to run it for 30 minutes before I even get warmed up!
As always, thanks for the help!
__________________
"And finally, it CAN BE DONE. It HAS been done by more than one member here." -PenMan1
Quality Pen is offline   Reply With Quote Top
Old 02-15-2019, 01:06 AM   #2 (permalink)
jttheclockman's Avatar
Photos: 104
Default
I prefer the larger slower speed wheel and motor. I use my buffer for other things than pens and with too fast of speed it burns the wood and you need o control the feed more so. The larger wheel covers more area without smudging. This problem comes up for me when applying wax. That looks like a nice unit. My setup is an old used motor that I adapted with a wheel and I need to spin the wheels on one at a time but I use the assembly line approach. I have 2 different sets of buffing wheels for metal and then a set for woods and plastics. Have to run a set of pen blanks tomorrow because I could not get a top shine with MM on this set of blanks for some reason.
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 02-15-2019, 08:45 AM   #3 (permalink)
robutacion's Avatar
Photos: 4
Default
I suggest the 8" ones, bigger wheels, more buffing area...!
I have just purchased a couple of weeks ago one of these, so far so good...!
Cheers
George
__________________
"Don't give others what you don't like for yourself"
Email: nyodine@yahoo.com.au
Web-Store: https://www.georges-bits-of-timber.com/
robutacion is offline   Reply With Quote Top
Advertisement
Old 02-15-2019, 08:57 AM   #4 (permalink)
JimB's Avatar
Photos: 11
Default
I use 8” Beall buffing wheels. I made my own extender from scrap wood and a T nut. I mount the entender on my lathe and the wheels mount one at a time. It takes about 10 seconds to change buffing wheels. By mounting on the lathe I have variable speed.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 02-15-2019, 09:14 AM   #5 (permalink)
BSea's Avatar
Photos: 51
Default
Quote:
I agree with buffing on the lathe regarding speed control. Plus it's easier to change out for wood/resin & metal. I've been looking for a smaller lathe to use just as a buffing station. Of course I could also use it as a mobile lathe for when I go to someone else's shop for tandem turning, or for a meeting.
Oh yeah, I also think 8" over 6" wheels. But I really don't know that it makes much difference. Maybe someone that has used both will chime in.
__________________
Bob
Central Arkansas IAP Chapter Member
BSea is offline   Reply With Quote Top
Old 02-15-2019, 10:19 AM   #6 (permalink)
Photos: 4
Default
Whether 6” or 8”, I swear by these buffing wheels
https://www.caswellplating.com/buffi...el-wheels.html
__________________
"In theory, there's no difference between theory and practice. In practice, there is."-Yogi Berra
Shock me is online now   Reply With Quote Top
Old 02-15-2019, 11:35 AM   #7 (permalink)
Photos: 4
Default
The diameter of the wheel, is relative to the size of the motor.
RPM and surface speed are irrelevant. Proper buffing practices are more important.
The wheel should be matched to the material, the compound, and the expected result. There are different wheels, for different purposes, as well as the different compounds. Wax is not a compound, and using a buff wheel to apply wax...smh. On a plastic pen, there is absolutely no benefit to applying wax.
On plastic pens, whether solid or coated, only two wheels and two compounds are absolutely necessary to get an excellent finish, provided the base prep was done correctly. If the base prep is incomplete, buffing only accentuates the imperfections.
There is much more to buffing/polishing, than buying the equipment.
Doing research, speaking with the tech dept. at your chosen supplier, and practice should help yield the desired results.
I have never buffed anything in my life.
Terredax is offline   Reply With Quote Top
Old 02-17-2019, 02:17 AM   #8 (permalink)
Photos: 4
Default
I've heard from people that make great pens say slower is better. What makes you say it doesn't matter though since that flies in the face of what I've come across?
I would very much prefer to buy a cheap standard grinder for 40 bucks rather than a low speed one at 3x that... but I figure it's a smart move.
As far as technique, definitely it's more important. You're spot on about that. Buffing is definitely an art and a science, and I'm just trying to continue my journey.
Also, as recommended the caswell wheels are great. That's what I use. I've found a lot of useful info from that old "buffing kicked up a notch" thread from years ago. Glad someone shared that!
__________________
Old 02-17-2019, 05:11 AM   #9 (permalink)
randyrls's Avatar
Photos: 68
Default
Beal makes a three on the lathe buffing setup for about $100. Just mount it on the lathe, and remove when done. Mine hangs in the corner from a double tool hook.
Really, 3400 RPM is much too fast for buffing wheels. Beal says 1100-1200RPM
__________________
Randy S.
Experience, ah, experience; Experience is what you get when you don't have experience!
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Old 02-17-2019, 07:27 AM   #10 (permalink)
TonyL's Avatar
Photos: 6
Default Buffing Wheels
This may help you decide. I wanted 4 wheels.
File Type: pdf 4 Stage DIY Polishing and Buffing System_updated 1_15_16.pdf (665.3 KB, 7 views)
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
