cbatzi01
Hi everyone,
Like many people, I am having a OOR or concentricity (more likley) issue with a jet mini 1014. I turn between centers using 60deg cones with no luck. If I try to line up the two points, the tailstock sits just behind the headstock point (in essence, they don't line up).
I have used a dial indicator and get about .01-.02 runout by checking it with a mandrel. What is really odd, is the hand wheel is all over the place. Visably spinning "funny" like it isn't seated correctly.
I have called JET support twice. Call #1 resulted in the hypothesis of a bent spindle or bad bearing (this led to the dial-indicator).
Today's follow-up call resulted in a different solution....twisting the lathe bed. The support guy suggested mounting the lathe to the bench and putting a shim under the opposing leg, and tightening it down in ord to twist the bed, and bring it in line. He also said the twisting it would be much easier than just shimming the tailstock with a piece of tape/metal.
I am looking for a second (and third, and fourth..) opinion before I go to down on my lathe. For the record the JET support people have been great. Very knowledgeable and eager to help. I was prompted to call after the comments from another member.
Has anyone ever heard/tried this?
Thanks in advance!
Thanks in advance!
