Woodpecker26
Hello All,
For a twist pen, when you turn it to expose the writing tip, it hits a 'stop' so you know when to stop twisting, and really should not turn beyond that. I have quite a few where the tube basically 'slips' and turns around the twist mechanism and you can keep twisting past the maximum open point. I don't know if these are manufacturing issues or slight variances in tube sizes, or maybe inside tube material honed out when trimming the barrel? I see these as defective pens, and you don't know if it's going to happen until the pen is done and assembled, then the beautiful pen you just made is useless. I've only used Penn State kits, and it has happened on different types of kits. Has anyone else that's run into this have any suggestions for how to fix, or even better, identify when it might happen?
Thanks in advance for your comments
