JBeck
I just turned a classic American style pen and everything is fine other than the fit between the upper blank and the twist mechanism. It is slightly too loose and when you twist the pen to extend the cartridge, it won't extend it unless a little downward pressure is applied while twisting. Does anyone have a fix for this situation? I was thinking about putting a small layer of 5-minutes epoxy inside the upper tube and letting it cure before putting the upper barrel back over the twist mechanism. I was thinking this might give me the tighter fit I need. Is there a better solution? More experienced advise would be appreciated. Thanks.
John
John
