wrightal3
Have experenced the following two problems recently on Berea pen assembly:
1) on RT Euro screw cap the centerband will not stay in place, it keeps working loose and must be re-pressed in place. I did not use any glue , just pressed it on. Should I use glue or is there some other trick?
1) on a Euro twist BP the Twist Hold which presses into the lower tube is threaded and screws into the twist mechanism with pressed into the cap tube. I assembled & screwed the cp into the twest hold but it rotated free and will not unscrew not will the entire mechanism pull out of the cap. Its a beautiful antler & hate to waste it.
Any help will be appreciated.
