Turning / Drilling Aluminum Help Needed
thetalbott4
Roy, Utah, USA.
I would love to get into the aluminum pen turning but am having trouble drilling the blanks. Looked in the archives and didnt find any specifics.
I have tried drilling fast, slow, and in between. Altered feed rates, and I bought some brand new bits with no change. I cant get further than 1/4" in before it starts guming up and causing problems. I gotta be missing something.
Is there an alloy that is better than others? Bits? Past that, what do I need to know about the actual turning?
smoky10
Shepherdsville, Ky, USA.
The best aluminum rod to use is 6061, it is softer and easier to turn. When drilling, on the lathe, I use high speed and mist with water to keep cool. Someone here told me to mist and it helps a lot. On the drill press go slow and squirt, in the hole, with water frequently.
Fangar
Wilton, CA, USA.
First thing to do is find a way to drill it on your lathe. It always works better to spin the stock and hold the drill stationary. I drill at 1800 rpm. You will need to use a light lube. Thread cutting oil is best, but I usually use WD-40. A 5/8" collet chuck works well for the 5/8" T6061 that I use. Also, a Scroll chuck with pin / dowel jaws. Here are some photos that I took recently:
This is a closed end being drilled, hence the step down on the last couple of photos. If you are drilling on a press, you will get quite a bit of wander, not matter what bits you use. You can see that I use the simple Titanium coated bits. Cobalt are better in my opinion for metals. A simple HSS jobber bit works fine too.
Cheers,
Fangar
PatLawson
Laguna Beach, CA, USA.
>>Is there an alloy that is better than others? Bits? Past that, what do I need to know about the actual turning?<<
6061 aluminum is what you need. I use regular drill bits (kept sharp with a Drill Dr.), and I use cutting oil when drilling and you also definiteyl need it for sanding/polishing if you want a highly polished surface. I put a little cutting oil on the drill and in the hole and it does fine.
For turning you can use regular turning tools and a wood lathe, but it does go slow and the chips are hot and sharp. It is much easier to do them on a metal lathe. If someday you want to try copper - definitely get a metal lathe! Copper is much harder and likes to "dimple" and give you a really bad time! It turns out beautifully on a metal lathe though.
Pat L.
Laguna Beach, CA USA
http://pensbypatricia.com/NewPens
PatLawson
Originally posted by Ron Mc
<br />...Where would one purchase 6061 aluminum rods?
Ron! Fancy meeting you here! [:)]
You can buy 6061 aluminum rod at Online Metals http://onlinemetals.com
They will sell you as much, or as little as you want. It's 52 cents a foot I believe, (plus shipping). And if you register on their site, you'll get 5% off every order.
Pat
Tom McMillan
Washougal, WA, USA.
When I made a couple aluminum and brass pens I got 6061 aluminum from a local hardware store (it's a pretty complete hardware store), and what I got was predrilled (perfect for inserting 7mm tubes. Probably cost a little more, but seemed easier than trying to drill the aluminun for me. Seemed like it came in about a 10 or 12 inch length.
Ron Mc
USA.
Pat? Is that you? [:D]
Thanks for the assist everyone! I may have to try this in conjunction with some other ideas bouncing back and forth in the abyss![;)]
Fangar
Wilton, CA, USA.
Though it can be done, I would not recommend using your nice HSS tools on the aluminum. The amount of heat generated can cause a change in tempering that might reduce the ability of your tools to hold and edge. I made a simple scraper out of an HSS steel cutter that I rounded on a grinder. I welded on a threaded rod and turned a handle for it. It is quite heavy and chews right through the aluminum. Here are some photos that I have posted before.
Cheers,
Fangar
TomServo
Grand Forks, ND, USA.
Talbott: a scraper is appropriate - you might also consider using a light oil when turning them. If you use a little oil (I use grease sometimes) it'll keep the temperatures down and you could use your regular turning tools. Aluminum is usually machined with HSS tooling in manufacturing.. Fangar has a good point with his HSS chunk there, but if you don't have the wherewithal to make a similar tool, you can easily use your regular HSS scraper, just use a little WD-40 or what-have-you when you turn it to keep the tools and aluminum from getting too hot. I think you would just use a very sharp edge, rather than having a bur.
Fangar
Wilton, CA, USA.
Originally posted by thetalbott4
<br />James- Is the scraper the only or just the best type of tool shape to use?
Scott,
Really for me, it is the shape that I use for most of my pen turning. That and my skew (Though very seldom for me). For the aluminum, I only use the sraper. Keep in mind I run my lathe at the highest speed for aluminum. 3200+ or whatever it is on the Jet. I ain't messing with no skew in that range! [;)] Also, a face shield and respiratory protection is required for me. Aluminum dust is not good.
Fangar
