dhallnc
I bought the slimline bushings along with the delrin bushings and tried to turn a pen today. I had some problems that I'm sure you folks will have easy answers for.
1. Using the metal bushings without a mandrel means turning one barrel at a time which I did. The problem I had was that by doing so, It was time consuming turning, sanding, then switching bushings to finish once for each barrel.
2. I found it hard to get the proportions I liked without seeing both barrels at the same time.
3. My finish came out with one barrel darker than the other due to uneven application of the CA. between the two.
I would like to have a middle bushing of both the metal & delrin to put in the middle with a double end so I could mount both barrels for turning, sanding and finishing. Does Johnny CNC make those for a slimline?
Any tips, suggestion or is that just the way it is?
Thanks.
Thanks.
