Turncrafter pro vs - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 09-02-2012, 06:10 AM   #1 (permalink)
rizaydog's Avatar
Photos: 0
Default Turncrafter pro vs
I just bought a Turncrafter pro vs from a friend of mine as a second lathe. It's much easier to turn small things on then my powermatic 3520.
The issue that I have with this lathe is with the tailstock lock and the tool rest lock. They are long levers that always seem to be in my way. I am trying to find start knobs that will fit this lathe. Does anyone know what size and where I might find knobs for this? I've checked all the local hardware stores without any success.
__________________
Come visit me at WoodChux and see my work, get free woodworking Plans, and find the lowest priced Bottle Stopper kits, Pinecone Pen Blanks, CA Glue, and other Woodturning Supplies.
rizaydog is offline   Reply With Quote Top
Old 09-02-2012, 11:25 AM   #2 (permalink)
PTsideshow's Avatar
Photos: 0
Default
Well they are made in the same factory as the Harbor Freight lathes.
http://manuals.harborfreight.com/man...5999/65345.pdf
Since you got it used you may not have the booklet this is basically the same one. Look on page 21 for part 6 and part 41 this is the locking assembly.
On mine there is a slotted screw loosen that, you will see a spring on the shaft, hold it so you don't loose it. Take it out and then pull the handle off, looking down the side that goes on the lock mechanism. You will see that there are v shaped notches all the way around the inside.
This handle can be moved so it is always out of the way in use. You will need to start out with both of them in the locked position. then adjust the holding screw till you can press the handle into unlock the clamp, then release and move the handle so it is out of your way. This is the same for both handles. if that isn't enough you can always shorten the length of the handles. on the harbor Fright ones they are plastic!.
It is easier to figure out play with the handles than it took to explain it in typing!
Hope this helps, no new handles needed!
__________________
Local Chapter member IAP
PTsideshow is offline   Reply With Quote Top
Old 09-02-2012, 12:41 PM   #3 (permalink)
Photos: 0
Default
I have the HF version of the same lathe. I too would like to replace those two handles. The one on the tool rest for sure.
I see yours is VS. I wonder if theres a way to adapt VS to my HF version?
BassBlaster is offline   Reply With Quote Top
Advertisement
Old 09-02-2012, 06:34 PM   #4 (permalink)
rizaydog's Avatar
Photos: 0
Default
Thanks for the info. I do know how to move the handles and I have the manual. However, I dislike the handles way too much. Cutting them is a good idea. If I can't find any knobs, I'll cut the handles.
__________________
Old 09-02-2012, 07:50 PM   #5 (permalink)
PTsideshow's Avatar
Photos: 0
Default
Quote:
Just keep in mind that the cam locking device that works off the v-notches on the inside has to be there on the knobs. if you real got to get rid of the handles. Get a couple of spares from HF make sure the new knob has a center that when drilled out will hold the center handle section drill the hole so the handle nub will fit epoxy it in and make sure the hold in screw and spring will work and you have new knobs to twirl!
__________________
Old 09-02-2012, 08:33 PM   #6 (permalink)
Photos: 0
Default
I have seen plastic at wood craft you can form or pour plastic handles or knobs if you break yours off on a machine. I would think if you can find the stuff and check it out first. Then cut you handles. Maybe make some slots or groves for the plastic to grip on, then pour your knobs. And hopefully it will work. May be know we're you can buy new handles if it does not work first.
Tom T is offline   Reply With Quote Top
Old 09-02-2012, 11:37 PM   #7 (permalink)
Photos: 0
Default
Am I missing something here? His picture is pointing to the handles that lock down the tool rest and lock the quill. Not the lock down lever for the banjo or the tailstock. I havnt had mine apart yet but these look like a standard bolt probably with a set screw type end on it with a plastic handle that is just way too long and is always in the way.
It seems to me, you could go to Woodcraft and pick up a couple of knobs with the proper threads and just use those instead. That was what I had planned to do but just havnt taken the time to figure out what the thread size is.
Old 09-03-2012, 06:43 AM   #8 (permalink)
Photos: 7
Default
Anyone knows if tailstock assemblies are interchangeable between this lathe and a Turncrafter Commander 12" VS? They look very similar. I am a real noob here but I think if they both run in the same width slot, then they should work. Or what else should be taken in consideration?
TIA
__________________
Best wishes
Ulises
We each have something to teach... and a lot to learn.
Ulises Victoria is offline   Reply With Quote Top
Old 09-03-2012, 04:53 PM   #9 (permalink)
PTsideshow's Avatar
Photos: 0
Default
If you remove the handle on the tool rest and the quill and look inside you will see the v notches that operate the cam lock which is the handle parts #6 and #41 on the parts list in the link, it isn't a regular bolt or screw. The handle slides over this and the bolt and spring keep it in place. See the link in my original post.
__________________
Old 09-03-2012, 05:35 PM   #10 (permalink)
Photos: 0
Default
I see now, allthough I dont understand how it works from the pic. I guess I need to take mine apart and educate myself!!
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
