G
Guest
Guest
If any of you cut your own tubes or have a situatiion where the pen mill "boogers" up the tube (like mine) I found a good solution.
I have a set of "step bits" I used to use a work.
One of the sizes that's labeled is1/4".
I chucked it into a keyless chuck I took off a drill( I hate keyless chucks)
It makes a great tube reamer.
Harbor freight has the whole set of step bits for about $15.00.
Mine is a Uni bit that costs a lot more but I would imagine any will work.
