tube for Sierra
wdcav1952
Activities Manager Emeritus
Jerry,
Given the group buy and the popularity of the Sierra, they are likely on back order most places. I just ordered a few Sierra Kits from Beartoothwoods, and the tubes are on back order.
gerryr
Billings, MT, USA.
If they have the right diameter, PSI sells tube material in 10"(I think) lengths that you can cut to whatever length you need.
Randy_
Dallas suburb, Texas, USA.
PSI, according to their catalog, sells five different types/sizes of brass tubing:
7mm x 10" universal,
8mm x 10" universal,
8mm x 10" pencil,
3/8" x 10" universal and
10mm x 10" universal.
The stated diameter is nominal, I assume , and not the exact size. Tubes also vary in wall thickness so a PSI 7mm tube may not work with every vendors 7mm kits. There have been some posts reporting this very problem.
The Sierra kit requires a 27/64" drill bit which is half a thousandth less than 10.7 mm and 0.028" larger than 10mm so I don't think the PSI tubes will work with the Sierra kit??
